416 LS3 e85 Nitrous plug question
Old May 25, 2012 | 02:56 PM
10secZ28's Avatar
Originally Posted by Fbodyjunkie06
It's a pre-ignition thing which is why you melted the 6 range. The plugs tip was way to hot and it stayed lit after the spark was fired thus turning it into a glow plug in your combustion chamber.
You should be on a 7-8 plug with that much compression on motor alone. If it doesn't run right with that plug in it, it's not the plugs fault it's the tunes fault.
When I went to a B8efs on my 200 shot(10.25:1 compression) I had to go from 13.8-14.2 to 14.6-15.1 AFR at idle to help keep them clean and from 13.9-14.3 during cruise to 14.6-15.0 during cruise. Granted it was really to rich to begin with the TR55's on motor covered that up. A hot plug with a rich tune is just covering up a rich tune.
Lean that baby out it WILL make more power, but when you lean it out you have to pull the timing back and put a colder plug in it to take the tip temperature back down and put the heat on the tip of the plug where it should be.
As the guy above me said a step lower heat range lowers the tip temp 140*. That's it. No lost power, just a cooler tip temp. A hotter plug or a colder plug contrary to belief will not make or lose any power itself. The tune not being correct for that heat range plug will.
I hope this helps and I am not trying to ride your *** or make it look like you don't know what you're doing, but you could really be doing it a lot better and make more power.
With your compression, and a 200 shot I'd be on at least a B9EFS and honestly I'd have -10's on deck.
Damn buddy were friends on fb and you still dont know who i am lol
Old May 25, 2012 | 02:58 PM
Fbodyjunkie06's Avatar
Is this Brandon?
10secZ28's Avatar
lol yea man
Old May 25, 2012 | 03:07 PM
thedudeZ's Avatar
no issues loading up plugs or fouling around riding around on e85 with number 8 ngk's. Plugs still look clean.
Been considering going back to 93 just because I'm out of fuel pump on 1 255 pump with a hotwire and 57lb injectors but it offers dumb tuners like me such a wide tuning window.
Old May 25, 2012 | 03:09 PM
lol yea man
Damn man!
Put a freaking picture of your car in your avatar or something, how am I suppose to know!?!?!
I don't have ESP or nothing, you know how many 370's with Th400's on nitrous there are? LOL
Old May 25, 2012 | 03:10 PM
I also only read like the first two lines of your post when I made that long reply, and then when after I made my post I read yours and realized he just said every single thing I just did lmao wasted all that time for nothing
10secZ28's Avatar
lol hasnt really been my first priority, but i'm done thread jacking this guy
Old May 25, 2012 | 07:15 PM
blackonblacksls's Avatar
I can keep 6s in it and run pump gas. Or e85 and the car still drives fine. Or I can run 7s or 8s and they foul the first time 93 octane hits them.
Like I said for what I'm doing the 6s work best.
And if I can run a 7 and spray a 250 with no changes in the time except for Timing then why not. This is a daily that gets sprayed occasionally. If I can avoid fueling change and such like y'all are mentioning then I'm
Better off. I can't even imagine driving around on motor with a 9 or 10 plug.
Old May 25, 2012 | 07:20 PM
So you run an almost 15:1 motor on 93 with a 6 range? You're blaming the plug when you're the one to blame for being lazy.
I guess when you have stupid money to blow you don't care if you melt motors and plugs down all the time.
I change my plugs 7/10 times when I go to cruise around to TR55's but if nitrous is going anywhere near my motor it's getting 8's on the tune-up I am currently spraying.
Since you tune your own car and know more than me, you should know it takes 2 minutes to go into your EQ ratio table and change your AFR. Once you lean it out, it's not like you have to richen it back up for the hotter plugs leave it alone.
You are blaming mechanics when they are being used improperly in the first place.
Old May 25, 2012 | 08:33 PM
I don't tune. I don't carry a laptop in the cAr. I don't want to deal with changing plugs just for a weekend. It's a daily. Not a race car. I want to put plugs in a car and drive it. I put synthetic in it and don't change it for 10k miles. I dont want to deal with ****. If I wanted to do race car **** I would build a racecar. Not a 4klb 2011 camaro on 20s.
Old May 25, 2012 | 08:36 PM
If I can spray 250 on the 7s. Nt deal with any of the extra crap. Why not?
Old May 25, 2012 | 09:07 PM
  #32
raymond mckinney's Avatar
What size tire are you running? 3:90's are going to be cutting it close going thru the 1/4 traps on spray.
Old May 25, 2012 | 10:55 PM
  #33
Do what works for you.
I understand not wanting to deal with all that, but at least try and do it the right way.
Old May 26, 2012 | 02:42 AM
  #34
What makes your way right and mine wrong? If they both get down the track without burning **** down? If the car runs and doesn't **** anything up on 7s? How is it not right? I have learned 6s are the wrong thing. But nothing says 7s are too.
Old May 26, 2012 | 08:50 AM
  #35
Do you not read any of the other posts? Everyone has agreed with what I am saying and others.
You just want to be stubborn and say I did it on this just to say you did it.
Does it make it right? No. Your motor is going to be an ashtray factory soon.
If you have anywhere near the compression you say you do you are a fool for thinking you are going to be able to get away with it.
I also find it funny that on Yellowbullet you told me I didn't know how to tune, and acted like you were some steve petty and now you come out and say you don't even tune or have tuning software?
Let me know how that 93 octane and 14.67:1 CR works out. Man some people just don't want to learn or listen.
You won't find but one person on the web who disagrees with what I am saying and that is that idiot Mark Sullens.
Old May 26, 2012 | 11:48 AM
  #36
I have been doing this **** for over 8k miles. Beating the **** daily on the way to and from practically everywhere. No issues. Funny how when I called you out on yellow bullet about having no first hand experience with e85 lsx cars you shut up. Now your here acting like an expert.
Run a hotter plug your better off. Lots easier to deal with.
Old May 27, 2012 | 03:57 AM
  #37
NXZ28's Avatar
Cool off. This isn't YB. Everyone is entitled to their opinior based off some hard learned lessons. If it works for you then great. The 7 is a tough plug. I accidentally sprayed a 250rwhp shot on pump gas with them. Car didn't miss a beat but the plug tip was white hot when I took them out. I do not like dodging bullets.
Old May 27, 2012 | 04:37 AM
  #38
Not gonna argue anymore.
Good luck blackonblack. I hope you have the respect to do the same.
Old Jul 4, 2012 | 02:31 PM
  #39
LIL SS's Avatar
Moderator
Any idea what your dynamic compression is? If not mind sharing your cam specs, just intake side, total duration and intake center line.
Any idea what your tuner set your total WOT timing to?
I would love to see a data logger just to see if the PCM is pulling any timing via Knock Retard at WOT. It is not always heard.
I'm not going to say a 14.8x motor can't run on 93 octane, but I would guess the intake valve would have to close rather late to be happy with any timing in the high 20's to low 30's.
