Nitrous Solenoid Problem (wont open)
1. Weak coil
2. Nippeling on the piston changing seat height.
3. Poor ground contact.
4. To high of bottle pressure due to gauge being off.
I would un wire the solenoids and run the power and ground straight to the battery. Then check the solenoid to see if it works. This will take any possibility of a wiring issue out of the loop.
Check and see what the bottle pressure difference is when the solenoid is working and then not working.
Dave
I just tested the solenoid and it seems to be opening just fine. So i rewired it back into the relay and the rest of the kit and both solenoids are clicking and seem to be working just fine. This was the first time the nitrous solenoid didnt work in the 4 years i had the kit, i dont know what the problem was. I know it wasnt a wiring issue because the nitrous and fuel solenoid are both powered and grounded at the same place and the fuel solenoid was working fine. I have a digital autometer nitrous pressure gauge. Are they known to be off?
hmmm weird one. Ok lets do this. With still jumping wires to battery slowly bring nitrous pressure up while checking solenoid fuction. Lets see where the solenoid stops opening pressure wise..
Dave
Other than that check all your grounds and wiring connections.
Dave
