Digital air/fuel ratio gauage......
Old Mar 13, 2002 | 11:19 PM
Slowhawk's Avatar
LS1Tech Sponsor
Default Re: Digital air/fuel ratio gauage......
They are fairly accurate.
The most accurate are ones that read and display the voltage.
Here is one
www.speedshop.org
Old Mar 14, 2002 | 12:00 AM
MAFs 00 Ws6's Avatar
Default Digital air/fuel ratio gauage......
I was looking thru the summit magazine yesterday and came across a digital air/fuel gauge that lets you know if your are running lean or rich. Has anyone ever used one? Are they reliable, and how hard are they to install? It looks like a good thing to have. Just curious if it actually works...Thanks..Michael
Old Mar 14, 2002 | 07:11 AM
Thanks Slowhawk that is excatly what I am looking for. <img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" /> you are da man.....Thanks again..Michael
Old Mar 14, 2002 | 06:40 PM
BADZ's Avatar
Moderator
its kinda hard reading the air/fuel gauge from summit but it does do that job... <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Mar 14, 2002 | 08:19 PM
2000 C5's Avatar
I see the A/F meter from speedshop uses the stock O2 sensors. I was told that the stock O2 sensors would not provide accurate information. Should I cancel my visit to the dyno shop with the wideband A/F testor, and purchase this meter instead?
Old Mar 14, 2002 | 11:09 PM
Slowhawk's Avatar
LS1Tech Sponsor
A dyno is always a good idea.The digital gauge gives the voltage exactly like the #'s you get with A-tap.
I would go to the dyno with the gauge installed and compare the readings.That way you know what voltage gives the power you want.
Old Mar 17, 2002 | 01:40 AM
cantdrv65's Avatar
Thanks Slowhawk, I ordered one Friday...I think it will work much better than the UFO gauge
Old Mar 27, 2002 | 10:09 PM
FASTZ71's Avatar
Correct me if i am wrong, but I believe you will need 'wideband' o2 sensors for those little gizmo's to even be worth a damn.
Old Mar 28, 2002 | 07:44 AM
Slowhawk's Avatar
LS1Tech Sponsor
People rely on them for reading there A-taps?
Wideband is better,but they are very expensive.
