Detonation and nitrous
<small>[ March 20, 2002, 01:36 PM: Message edited by: 383LQ4SS ]</small>
1) cylinder pressure reaches its peak as the piston is still traveling upward in the bore;
2) burn rate becomes too great and combustion temp get way too high.
Usually both occur to some extent depending on how bad it is. The second issue (heat) is usually what lead to ring land and ring issues, 'burned' pistons and exhaust valves. The pressure issue is what can actually break a piston (and the extra heat contributes as well). Forged pistons increase the safety threshold over the stock cast ones trmendously. Understand what you're doing and how timing is involved, watch your A/F, start small work up from there.
