What jets?
Old Mar 25, 2002 | 09:57 PM
SRT T/A's Avatar
Default What jets?
I have a NX single nozzle wet kit, and I do not have a calibration card. Can someone tell me what jets will make 150hp. And can anyone tell me if they think it is safe to make a few passes at this setting with a stock setup. Trying to get about a 12.0 or better out of the car. Can it be done. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Mar 25, 2002 | 10:17 PM
rich's Avatar
Default Re: What jets?
the jetting is as follows 35n 18f 50hp, 41n 22f 75hp, 52n 31f 100hp, 62n 33f 150hp.That is it with a 100 hp dry kit as the only mod I went 12.64 1.95 60ft on eagle 1's spinning like crazy.I had to let the car roll out about 15 to 20 ft before spraying to keep it from spinning real bad.A set of dr's helped a great deal,cut it down to a 12.23 108mph 1.73 60ft.With a 150 shot if you get it to hook up you may even get a 11.90 et out of it nx kits are alot closer to actual rwhp numbers compared to nos.If you have an auto trans a converter will put you in the mid 11's.Just something to think about. Good luck!! Rich <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
