A4 and nitrous
Old Apr 1, 2002 | 07:46 AM
99MONGOOSE's Avatar
Default A4 and nitrous
I am thinking about adding 150shot of NX wet to my 98 Z28 aith an A4 and 3.23 gears. I also want a 3500- 4000 stall and trans cooler. Will the A4 hold up, or am I gonna be standed at the track? Othere then that car is stock.
Old Apr 1, 2002 | 10:10 PM
rich's Avatar
Default Re: A4 and nitrous
I ran a 125hp dry kit last year with the tci street fighter converter about 3200 on the high side. I didn't use a window switch and didn't have any problems (knock on wood). It went 1.60 in 60ft with a little wheel hop in a 3900# convertable. If I were you I would use a window switch will help save the trans for awhile.
Old Apr 1, 2002 | 10:46 PM
Slowhawk's Avatar
LS1Tech Sponsor
Use a window switch to shut the Nitrous off between shifts(saves tranny)
Also the Nitrous will flash your converter higher than going Natural,So take that into account.
Old Apr 1, 2002 | 11:52 PM
Slow Z28's Avatar
TNT 100 shot jetting, Vig3200, 3.23's, stock trans, MTI lid, Loudmouth, HPP adjusted shift points, MAF-Translator got me
11.54 @ 116mph w/ 1.58 60ft
if you run the window switch, it'll save tranny life a bit by not spraying through the shifts like mentioned above. i used a window switch, set at 3000 on and 6200 off. good luck man, and the vig3200 has proven to be a pretty good nitrous/NA converter. otherwise if you plan on spraying a lot, you might looking into a Yank PYE3400 or PYE3600
Chris
