Bottle pressure question
Old Apr 4, 2002 | 12:42 AM
WMSuperSport's Avatar
Default Bottle pressure question
Today I juiced it with only 800 psi and it seemed kind of weak. My bottle might be empty but Ive only put about 7 good sprays thru it. Is 800 psi too low??
Old Apr 4, 2002 | 02:02 AM
383LQ4SS's Avatar
Default Re: Bottle pressure question
On a dry kit bottle pressure = flow of nitrous. So yeah...the lower the pressure the lower the HP. To compare at 900 psi on the 140 pills I got 570 rwhp. At 1200 psi it was 623 rwhp.
Old Apr 4, 2002 | 01:05 PM
so does the bottle warmer keep track of what pressure the bottle's at or does it just keep a consistent temp? hopefully it gets hotter as more nitrous is used. correct?
Old Apr 4, 2002 | 07:03 PM
383LQ4SS's Avatar
The NX bottle heater has a pressure switch that controls the system. Works well from what Im told. As pressure drops below a set point it will turn the heater on. When the pressure rises to a certain point the heater shuts off. As the bottle empties the heater does not get hotter...just stays on longer to mainatin psi.
The rest uses a thermostat type switch to maintain a temp. Doesnt work as well ...especially when the bottle is very low. Most with this type of system bypass the thermostat and just monitor the psi via a gauge and turn off and on as necessary.
