timing ?
Old Jun 27, 2012 | 08:17 AM
jt_2002_ta's Avatar
Default timing ?
Wanting to re-tune my pcm and then add a timing box to pull the timing when I spray. My ? Is will the msd timing control box pn8680 work? And how easy are they to hook up,or should I go with the lingenfelter? Money is tight and the msd is half the price so if it will work I would like to use it. Thanks guys.
Old Jun 27, 2012 | 04:53 PM
87silverbullet's Avatar
That's not the box you want. That box requires you to have an MSD ingnition already in place. The one from MSD you would want is the 8625. Its just as expensive so I would say just save your money.
I would also buy the lingenfelter unit. Installs in like 5 minutes.
Old Jun 27, 2012 | 11:14 PM
99T/AMAN's Avatar
I bought the lingenfelter one and its great. Like said above, takes a couple mins to install
Old Jul 6, 2012 | 04:51 PM
Chris@NitroDaves
Guest
Posts: n/a
I know it's little pricey when compaired to the MSD unit but in all honesty you are going to be a heck of a lot better using the Lingenfelter unit. It is super easy to hook up and when not using the 2 step portion you literally only have to worry about one wire. Also it's the only unit that you can hook up to a voltage gauge or tuning software and see the timing being pulled. Everyone we have sold them too has been satified and happy with the unit.
Old Jul 7, 2012 | 09:48 AM
So easy even a caveman can do it! LOL!
Old Jul 13, 2012 | 04:25 PM
Chris@NitroDaves
Guest
Posts: n/a
Yuuuuup...lol
