MSD RPM Switch......Question
Your gunna wunna hook it up as follows:
RED-To a 12 volt source you have on a <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" /> switch
BLACK-To a good ground
WHITE-To the #10 pin on the most forward 1/2 of the computer it is white
YELLOW-this one will hook to your solonoids, remember that this will send a ground to them not a hot, so the other line from the solonoids will be a constant hot.
And lastly don't forget to cut the blue & red wire on the MSD module as to set it for a 4 cylinder.
Good luck, And I hope I was some help! Let me know.
Noids draw about 15 amps, the MSD is good for 1/2 amp. You need to isolate it using a relay.
Ryan.
