Nitrous wiring problems, need help!
Old Apr 7, 2002 | 10:33 AM
Gimp98TNT's Avatar
Default Nitrous wiring problems, need help!
heres the situation i had the edlebrock nitrous kit, but i switched to TNT using thier conversion kit. now every time i try to use it it blows the main fuse. The edlebrock kit uses a 15 amp fuse i've tried a 20 amp with same results. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Apr 8, 2002 | 02:47 PM
Chris Spiess's Avatar
Default Re: Nitrous wiring problems, need help!
What are the amp ratings on the solenoids in total? You'll need to fuse it above that value.
Old Apr 8, 2002 | 06:03 PM
383LQ4SS's Avatar
Also....check the resistance accross the solinoids. Ask TNT what that should read. You may have a shorted coil. I am assuming you didnt change any wiring or switches? Just added the TNT noids and hoses and jets?
Old Apr 9, 2002 | 01:17 PM
Gimp98TNT's Avatar
thanks for the suggestions guys got ahold of tony at TNT he going to help me out.
