MSD window switch delete.
Old Jul 3, 2012 | 05:06 AM
zooguy's Avatar
Default MSD window switch delete.
so i have done lots of reading and have come to the conclusion that because my car is an auto i really dont need a window switch. i got it cause i had heard and seen what happens if you spray at to low of an RPM. i have a 3000-3200 vig stall. so once i floor it the rpms are high enough for me not to worry.
so what do i need to do to delete the MSD window switch and KEEP the WOT, and FPSS.
Old Jul 3, 2012 | 08:29 AM
zooguy's Avatar
anyone?
once i get this done i can put in my colder plugs and i can spray for the first time
Old Jul 3, 2012 | 08:36 AM
TransAmcoupe98's Avatar
buy a mechanic WOT switch and a FPSS that mounts at the rails.
Old Jul 3, 2012 | 09:10 AM
Neal@NitrousOutlet's Avatar
If you really want to get rid of the window switch just buy a WOT micro switch and bracket. Then just wire it up.
Just on a side not just because its auto doesn't mean that it will not tap the rev limiter. This will also cause a nitrous back fire. A window switch is a great safety feature. If you already have it might as well use it but its up to you on if you want to use it or not.
Old Jul 3, 2012 | 09:47 AM
zooguy's Avatar
well its on the car and every thing is wired up how the diagram shows but ... no matter what i set the window switch to it sprays when i press the WOT switch even when the car is at idle. i found this out when aiming the nozzle in my elbow.
Old Jul 3, 2012 | 11:12 AM
are you running a WOT micro switch and a window switch?
Old Jul 3, 2012 | 11:16 AM
zooguy's Avatar
yes ... and a FPSS ... i have the exact diagram as above
Old Jul 3, 2012 | 11:52 AM
Nitro Dave's Nitrous Outlet's Avatar
What rpm setting do you have the controller on. Sounds like you have it programed wrong. Set the RPM setting on 4 cylinder.
Dave
