install question...
Old Apr 20, 2002 | 05:14 PM
B18B1LS1's Avatar
Default install question...
Where is the best/easiest place to run my supply line and all my wiring through the firewall?
Thanks
Jeff
Old Apr 20, 2002 | 05:23 PM
383LQ4SS's Avatar
Default Re: install question...
I ran mine through the driver side behing the clutch master cylinder area. Right were alot of the other main wires go through. I used a step drill from the inside of the car and opened it up quite a bit. You never know what you be running through there in the future. In retrospect I should have made the hole bigger because I am out of room. Also use some sort of chaffe gaurd or grommet if you can get one.
Old Apr 20, 2002 | 05:36 PM
B18B1LS1's Avatar
so you just made a new hole?
Old Apr 22, 2002 | 01:58 PM
MAFs 00 Ws6's Avatar
Best place to run all the wires is thru the rubber grommet under the PCM. Just remove the PCM and stick a hanger or something small to poke a hole nad then feed the wires thru. Just be sure not to push out the grommet. I ran all my wires thru there. Good Luck..Michael
Old Apr 22, 2002 | 08:28 PM
rich's Avatar
I did the same as Mafs 00 ws6 but I pushed out that gromet and installed a bigger one that would house the line a bottle press. line fuel press wires line lock wire. The hole is about 1 inch in dia. if not a little bigger.
Old Apr 22, 2002 | 08:38 PM
B18B1LS1's Avatar
I ended up using that grommet also. It worked great. The hardest part was getting the PCM in and out.
Thanks for the help
Jeff
