Need suggestions on complete nitrous system.
Old May 2, 2002 | 12:36 AM
Elite_Hot_Rod's Avatar
Default Need suggestions on complete nitrous system.
I am thinking about getting a nitrous system for my car and I need some advise from experienced nitrious users. I have a 99 T/A which weighs about 3800 lbs(I know its a pig). It's my daily driver but I go to the track almost every weekend. I have a big MAF,80mm t/b, holley intake,h/c,FLP LT's,18" bullet, cutout and a Corsa, 3200 stall and 3:73's. It dyno's at 385 RWHP/374RWTQ unlocked thru the exhaust.Locked thru the cut out it makes 405 RWHP/409RWTQ. I ran a 7.834 @ 87.5 MPH with a 1.732 60ft on ET Streets. I want to do a little bit better so I am thinking of nitrous, I don't think a big shot is really necessary and want to get the best of everything I need. What do you suggest? Thanks for your help,
Mark
Old May 3, 2002 | 12:08 AM
Chris Spiess's Avatar
Default Re: Need suggestions on complete nitrous system.
If you're already putting down 400+ count on upgrading your fuel system - pump and injectors for a dry shot, or a pump upgrade or dedicated pump for wet. Personally I favor dry, but there pros and cons to both wet and dry shots. Make sure you get the safety stuff...yada, yada, yada...a heater is good, a bottle opener is nice to have if you're putting the bottle all the way in back.
