how often is a refill neccessary
Old May 6, 2002 | 06:52 PM
alexWS6's Avatar
Default how often is a refill neccessary
don't really know much about this stuff, so say you have something like 100-150 shot, for example how many 1/4 runs would that last you?
Old May 6, 2002 | 07:31 PM
Postal's Avatar
Default Re: how often is a refill neccessary
Depends also on if you purge. I'd guesstimate 5-7 runs. I usually get no more than 7 runs, and that's if I'm lucky. I'd say just to be safe. After 5 runs I would refill it. Low N20 in the bottle will not really get good pressure even with the bottle warmer on. Low pressure is just going to give you a light hit when activated.
Old May 6, 2002 | 08:28 PM
alexWS6's Avatar
cool, thanks for the info
Old May 6, 2002 | 09:19 PM
2000 Camaro SS's Avatar
I get 7-8 runs with a small purge on a 100 shot. This is with using it in all gears.
Old May 6, 2002 | 09:22 PM
Navy David SS's Avatar
I run a 15lb bottle. Have 8 runs on it - I purge. Still holding at 900+psi (on a cold day).
David
Old May 6, 2002 | 11:39 PM
rich's Avatar
just keep the bottle press about 900 to 1050 psi and you will be ok and run all day with a 15 lbs bottle. If you have a wet kit the pressure is more important because it will cause a rich condition and loose power a dry kit will just loose power.
