Quick wiring question
Thanks,
Mike
for the battery to tnt relay, and from the tnt relay to solenoids, you should run some heavier gauge wire, as that can drawup to 28 amps, if you have the large noids. I would use 16 or larger
same with purge 16 or larger
Ryan
I drew out the wiring on paper, and actually just found a mistake after reading your response. I had the black power lead on the heater relay set up to a keyed power source, rather than the batter treminal.
Thanks,
Mike
Mike
with 8 gauge wire, your not going to want to really bump the system really hard, and run the heater, as 8 gague is generally good for 40 amps, and the heater will draw around 20. But for normal listening, you should not have a problem.
Ryan
