what pressure is FPSS set?
Old May 9, 2002 | 04:50 PM
fastlif's Avatar
Default what pressure is FPSS set?
I guess more specifically , what should minimum fuel pressure be when spraying? Mine looks to be dropping to around 35 or so psi, is this correct.
thanks, <img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" />
Old May 9, 2002 | 07:41 PM
akw408's Avatar
Default Re: what pressure is FPSS set?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by fastlif:
<strong>I guess more specifically , what should minimum fuel pressure be when spraying? Mine looks to be dropping to around 35 or so psi, is this correct.
thanks, <img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I hope 35psi is a typo.
53psi is more like it.
Old May 9, 2002 | 07:45 PM
fastlif's Avatar
no, seriously..at WOT it drops from around 40 to ~35, on spray or not
Old May 9, 2002 | 08:05 PM
akw408's Avatar
<strong>no, seriously..at WOT it drops from around 40 to ~35, on spray or not</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Might want to check your gauge. It sounds way too low.
<small>[ May 09, 2002, 08:06 PM: Message edited by: akw408 ]</small>
Old May 9, 2002 | 09:08 PM
fastlif's Avatar
my gauge was bad, i only had a 60 psi and its maxed out at idle, i will get another 100 psi tomm. i hope. thanks
Old May 10, 2002 | 06:17 PM
akw408's Avatar
<strong>my gauge was bad, i only had a 60 psi and its maxed out at idle, i will get another 100 psi tomm. i hope. thanks</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No problem.
