timing tuner ??
Old Aug 22, 2012 | 10:02 AM
ABQ99TA's Avatar
Default timing tuner ??
I have wired it all up and read the instructions. I understand everything but how to set the low RPM window setting. If anyone can shed some light I would really appreciate it.
Old Aug 22, 2012 | 06:26 PM
ABQ99TA's Avatar
Nobody using this anymore? I just don't see anything in the instructions about the procedure for the low rpm setting just the high.
Old Aug 23, 2012 | 09:50 AM
Chris@NitroDaves
Guest
Posts: n/a
Once you have done the initial programming of the switch you'll take the RPM switch and set it back to 5 which will give you a 3000rpm activation and your set.
Old Aug 23, 2012 | 10:46 PM
ABQ99TA's Avatar
Thank you sir.
Old Aug 24, 2012 | 10:59 AM
Chris@NitroDaves
Guest
Posts: n/a
Your welcome.
