Poll: 150 shot too much?
Old May 16, 2002 | 10:35 PM
racin jason's Avatar
Default Poll: 150 shot too much?
i have a 98z28. the 98's naturaly run ritcher, so i dont think that will be a problem. im running an NX wet kit.
Old May 19, 2002 | 07:19 PM
Colonel's Avatar
Default Re: Poll: 150 shot too much?
So long as your fuel system is up to snuff and you take the standard safety precautions, it should be ok. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Old May 19, 2002 | 10:38 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Colonel:
<strong>So long as your fuel system is up to snuff and you take the standard safety precautions, it should be ok. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">by that do you mean. FPSS, Window 3k-6k, full throttle, tr6's gapped at .38-.40? anything im missing, assuming that the stock fuel system is working properly. which a-tap confirms. oh yeah i have MAFT on the rich side to be safe also.
Old May 20, 2002 | 01:16 PM
Colonel's Avatar
Yes, but personally I'd rather have a pillar mounted FP gauge than a FPSS. Not that a properly set and working FPSS isn't a good thing. I just feel that seeing is believing.
Start with the jetting low and work your way up paying close attention to the fuel pressure.
Old May 27, 2002 | 07:10 PM
lafnatu's Avatar
racin jason, i'm having the same set up put on right now, why are you spraying 3000-6000 when you have a 3500 stall, do you plan on spraying off the line, do you know if its ok to run 2 maft, 1 for n/a and 1 for n2o, colonel, you know if this is a good idea. does the computer respond immediatly to the maft's signals or does it take time to learn them??
Old May 28, 2002 | 07:13 PM
lafnatu's Avatar
i guess it depends if you want to spray off the line, after reading the colonel's nos files last night i'm not even going to get a window switch.
Old May 29, 2002 | 12:50 AM
hummm, i thought thats what everyone did....? so should i do 3500-6000?
