OK........Takeing my noids apart to clean them
Old May 17, 2002 | 11:58 PM
TBaGZ's Avatar
Default OK........Takeing my noids apart to clean them
I want to take my noids apart to clean them and replace the seal if nessecary....Is there anything special I should know or any special toll i will need?.............better yet does anyone knoe where I can read or see a step by step on doing it??
Thanks
TJ
Old May 18, 2002 | 11:20 PM
TBaGZ's Avatar
Default Re: OK........Takeing my noids apart to clean them
anyone? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old May 19, 2002 | 09:32 AM
Country Boy's Avatar
Senior Member
The noids are reallllly easy to do. Its looks hard but theres only 8 parts inside one.
1) the top nut
2) the coil cover
3) the coil
4) the piece that houses the plunger
5) the plunger inside
6) rubber o-ring
7) the base
8) spring under plunger
Just take off the top nut, pull the cover off with the coil in it. The you will have to unscrew the base. It has 2 holes in it. I used a punch and a hammer. Unscrew the 2 pieces, theres a rubber O-ring inside along with a little plunger and a spring behind the plunger.
Thats all. Theres nothing to it.
Old May 20, 2002 | 11:49 PM
akw408's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by TBaGZ:
<strong>I want to take my noids apart to clean them and replace the seal if nessecary....Is there anything special I should know or any special toll i will need?.............better yet does anyone knoe where I can read or see a step by step on doing it??
Thanks
TJ</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'm pretty sure there is a special tool you need, I tried to open mine before and couldn't get very far.
Old May 21, 2002 | 01:29 AM
TBaGZ's Avatar
yeah it kinda looks like you need a spanner wrench to fit in the holes and open it
Old May 21, 2002 | 02:36 PM
Senior Member
Thats the name of it. i just used a punch or flathead screwdriver. Go to the local speedshop, they should have one. Unless its a TNT noid. They have a different size.
Thats how I did mine.
Old May 21, 2002 | 03:55 PM
Tony TNT's Avatar
Country Boy your scaring me <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> . Like my shop teacher told me back in high school use the right tool for the job <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old May 22, 2002 | 04:11 PM
Senior Member
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Tony TNT:
<strong>Country Boy your scaring me <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> . Like my shop teacher told me back in high school use the right tool for the job <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">LOL Tony. I had to get it off. I was one of the 3 that had the fuel noid plunger seal swell, remember? I had a friend give me the wrench, but it was too big. It was for the NOS noids <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
But hey, Im a construction worker and a redneck, ya gotta do what ya gotta do <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> I have lots of tools. lol
<small>[ May 22, 2002, 04:12 PM: Message edited by: Country Boy ]</small>
Old May 22, 2002 | 05:11 PM
RyanJ's Avatar
SSU Moderator
so, when you unscrew the top nut and remove the coil and cover, you use a punch to turn the base. like put the punch in one of the shallow holes on the top of the metal base, and tap till it breaks loose, then unscrew it? cool. perhaps i could just find a new seal rather than send my sol. in for too long to get it fixed.
Ryan
Old May 22, 2002 | 06:10 PM
Senior Member
Thats all I did, I actually uses a flatheaded screwdriver. The only thing thats goes there is the coil sits on it.
Old May 22, 2002 | 06:38 PM
RyanJ's Avatar
SSU Moderator
i emailed NX to see what they would do, but i may just pull it apart. would a seal like that be easy to replicate at home depot or something?
Ryan
Old May 22, 2002 | 07:55 PM
Senior Member
The seal that you need is part of the plunger. You have to get that from NX.
