NX help
I'd disconnect the N2O from the fogger and test it. Any idea what your bottle pressure is? What jets are you using? Could it be that the jets are switched or the lines are running to the wrong ports on the fogger? Just throwing out ideas.
Dave
Dave
Dave
1.Does the solonoid work ok.
2.Does the main feed line have any trash in it,or is it kinked.
3.Is your car running to fat on your set up..
4.Is your car leaning out? You may have a weak pump..
5.CHECK AND MAKE SURE YOUR MICRO SWITCH IS MAKING A GOOD CONNECTION WITH THE THROTTLE LINKAGE. I have seen it kick in and then the linkage rows alittle further and then disingage.
Good luck
Dave
