#1 cylinder burnt plug?
Old May 28, 2002 | 11:52 AM
fastlif's Avatar
Default #1 cylinder burnt plug?
Has anyone had this problem? All other plugs look great if not rich... I am using 52/35 jetting which should be dead rich. (NX kit)
over 60# fuel pressure, 1000# bottle pressure. Could it be just the physics of reaching #1?can the fuel in a wet sytem make that hard turn in the intake? OR Do I have a more serious problem? Car runs great with new plug, I want to drive for a while and see if this cylinder looks lean on motor.
Any ideas?
Old May 28, 2002 | 01:39 PM
fastlif's Avatar
Default Re: #1 cylinder burnt plug?
between MAF and throttle body on drivers side, about center of hose.
Old May 29, 2002 | 12:34 AM
383LQ4SS's Avatar
Where do you have your nozzle mounted?
Old May 29, 2002 | 10:02 PM
fastlif's Avatar
anyone?
Old May 29, 2002 | 10:53 PM
383LQ4SS's Avatar
I think your initial idea of running the car without nitrous and pulling plugs to see if its lean on motor is a good starting point. If that checks ok maybe start over again with a small shot while checking the plugs right after a WOT spray run. If its still lean I would adjust the aim point of the nozzle and try again.
Anyone else actually run into this?
Old May 29, 2002 | 10:54 PM
383LQ4SS's Avatar
What size shot are you running and what other mods do you have?
Old May 30, 2002 | 08:20 AM
fastlif's Avatar
its a heads/cam car with all bolt ons, running around 100hp shot. actually 100hp n2o jet (52)and 150 hp fuel jet(35). I have in line fuel pump to make sure it has enough fuel. o2's read .93-.95 on spray.
