msd window switch problems
plz help me lol, just give me a ideal if it ur not 100% of how to check
is there a way to check the msd 8956 to make sure its ok
There are many ways to do this.
MSD RED : to arming switch power
MSD YELLOW->WOT SWITCH->PIN85 of NITROUS NOID relay; this will provide a ground loop to the relay on PIN85. PIN86 of the relay to ARMING power. Nitrous will therefore trigger when the WOT and WINDOW are active.
You only need one relay.
MSD BLACK: GROUND
MSD WHITE: PIN10 TACH INPUT; I don't think you can use that device directly connected to one coil wire; unsure but because you can't set it to 1 cylinder mode, don't think it will work that way so I would suggest using the TACH input from the PCM, solid white wire off PIN10 of RED connector.
RELAY:
PIN30: Fused battery power
PIN87: positive power to noids
PIN86: Arming Switch Power
PIN85: From WOT Switch which is supplied ground by MSD as indicated above.
To add a FPSS, just add it to the ground loop. example:
MSD YELLOW->WOT SWITCH->FPSS->PIN85 RELAY
Positive power on the relay on 85? WTF. I would replace it to make sure its good. That doesn't sound right.
hope that helps..
