HSW Module and More...
Old Sep 28, 2012 | 08:37 PM
LASTOFTHEBREED02T/A's Avatar
Default HSW Module and More...
I have an Hsw timing Air to fuel ratio module, and wanted to see if anyone could help me figure out how to install it, and how to work the retard dip switches. Im upping the shot from a 36 pill, to a dry 100 shot. Got some tr6 plugs going in with my heads swap tomorrow, And also wanted to know if theres anything i have to be aware about spraying into some cnc 5.3 heads. Im still on stock bottom end, and wanted to know what would the limits of it, as far as horse power/rpm range.
Thanks...
Old Sep 29, 2012 | 01:30 PM
blacktransam's Avatar
everyones about to blow the door down and tell you to ditch the tr6 plugs. LOL I personally ran them for years with out issue but there are better plugs out there.
Old Sep 29, 2012 | 03:57 PM
minytrker's Avatar
What kind of wideband are you trying to hook up to it?
Old Nov 28, 2012 | 10:17 PM
I dont have a wideband, im trying to figure out how to install to my dry nitrous set up.
I have the dry zex solenoid box, with calibration button for WOT that engages solenoid. No window switch or WOT relay/switch.
