01 vette nos?
Just looking for others feedback I COMPLETELY New to NOS looking for as much info I can get
What kinda whp am I looking at Any links where I can get all stuff I need.
Im running full boltons and a bolton tune on my 150 shot pulling 6 degrees with a lingenfelter launch controller. Also run a colder plug ngk 3346.
Dont spray under 3k rpm and dont spray in 6th gear. Id say 500 rwhp give or take a few pending on n20 kit and car. With a good tire Ive sprayed in first it does spin but not blow them off.
So if you were wanting to spray more than 150 even though you dont have a cam I would recommend hooking up a fuel pressure gauge just to keep an eye on it to make sure you dont have any pressure drop.
You can also put a fuel pressure safely switch in there just in case your pressure drops and you dont catch it in time it will cut off before anything happens.
If you are interested in getting into a system give me a call and we can go over all of the details that you will need to know and I can answer any questions you may have just so you dont get any misleading info.
Trey
Trey
Call this man!!! He will get you hooked up in no time!
Next thing you want to look at getting with your nitrous system is the correct spark plugs for your set up. Since you are a blot on looking to hit 150 then BR7EF non-projected tip spark plugs would be the best bet for you. I would gap them around .030".
A great addition is a window switch. This can keep you from spaying to low in the RPM creating excess load on your motor. The window switch can also keep you from spraying in the upper rpm where you run the risk hitting your fuel cut on your motor. Both these conditions can cause nitrous back fires. Window switches can help to lessen the risk of causing a nitrous back fire because of these conditions.
For a 150 shot you can get it done with either a nozzle or a plate. 1/16 nozzles are good for around 200hp and 1/8 nozzles are good for around 250 hp worth of nitrous. Plates on the other hand can handle up to 300 and sometimes more jetting. Plates do offer a advantage for the atomization of the nitrous. This is because the nitrous and fuel are broken down over more area and discharges. This is why they can support more nitrous flowed through them and atomize better than nozzles.
Plates will offer more of a fail safe when installing them. Nozzles and be clocked wrong in the intake and can cause the nitrous to not atomize correctly.
If you are looking for any help of any information feel free to contact me.
