Swollen nitrous plunger
Old Oct 4, 2012 | 03:14 PM
cyipher's Avatar
Default Swollen nitrous plunger
Is this "swollen"? while it does look like there is a ring from where the plunger sits on the seat of the solenoid it doesn't appear to be "swollen", The center Teflon doesn't look to be any higher then the Teflon outside the ring indention.
Is this normal or bad?
Old Oct 4, 2012 | 03:37 PM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
That is normal for the Teflon to do that. Some types of Teflon are more prone to do that than other but it looks normal. The center will eventually start to protrude to far out and restrict flow after time and then it would need to be replaced.
What exactly are you trying to find out? Is it nor flowing enough, not opening, leaking?
Trey
Old Oct 4, 2012 | 03:58 PM
Neal@NitrousOutlet's Avatar
That look pretty normal as long as that ring isnt to deep.
On thing that sticks out to me is the junk on the teflon. Was that there when you took it apart or was it caused by you taking it out and moving it around. I would take a soft bristle took brush and clean that off.
If it was there when you took it apart i would check to make sure that you arent getting any junk in that solenoid.
Old Oct 4, 2012 | 04:44 PM
cyipher's Avatar
Trey
Trey,
I called and talked to you about the jet size issue and you truck eariler, a buddy said to check the pluger so i just wanted a second oppinion on it. i will be tryint the 41f jet as we discussed.
Neal,
I just pulled the solenoid back apart to check it the trash isnt there. must have been from my fingers or something.
Old Oct 4, 2012 | 04:52 PM
Yeah that plunger looks perfectly normal to me as long as that wasn't trash on the Teflon part. Hope that jet gets you where you want to be, if not let me know and we can try to figure something out on it.
Trey
Old Oct 5, 2012 | 09:38 AM
Originally Posted by cyipher
Trey,
Neal,
Cool just wanted to make sure that didnt get over looked.
