2003 silverado
Old Oct 13, 2012 | 12:46 PM
caddi1's Avatar
Default 2003 silverado
How big of a shot can a bone stock 4.8l truck handle?
Old Oct 13, 2012 | 01:14 PM
jaybuller's Avatar
Shoot it and find out..hahaha, the 4.8s are cheap enough! If the tune is right I bet a bone stock 4.8 with no mods could handle over 200 no problem, if the rpms are kept stock and don't spray below 3000rpms. Probably way more but that would be my safe answer...
Old Oct 14, 2012 | 07:59 PM
JoeyGC5's Avatar
The stock 167k mile 5.3 in my GMC before the entire drivetrain swap got 15 bottles of a 150hp shop through it before being pulled out with no damage.
Old Oct 14, 2012 | 08:56 PM
BudRacing's Avatar
It's all in the tune and staging. If your setup is spot on you shouldn't have any trouble. It only takes one error to royally screw up your engine.
Old Oct 15, 2012 | 09:34 AM
jaybuller's Avatar
bud racing... that is as true on a stock motor as it is on a full prepped race motor. Trust me. back in the day i destroyed a motor i had built with forged pistons,rods ,crank rings gapped big the whole setup set to spray. i had sprayed it at the track for a year or so on and off then one night my fuel selenoid malfuntioned on the nitrous kit and it ran to lean and melted down the edges of the piston crowns. this was all on about a 200 shot.
Old Oct 15, 2012 | 10:18 AM
Neal@NitrousOutlet's Avatar
depending on what you already have done to your engine.
The thing you will have to look out for is the fuel system. Depending oh what year vehicle you have will determine how far you can go on your stock fuel system.
If you have the right spark plugs, enough fuel, right amount of timing pulled out, and window switch, its not uncommon for that motor to see 150 hit on it. Sometimes more with good tuning.
