how important are bottle heaters and purge sols?
Old Jun 19, 2002 | 10:51 AM
gator's 99TA's Avatar
Default how important are bottle heaters and purge sols?
just wondering. i am trying to learn about the world of nitrous. can you get away with just a base type kit like the NX kit or do i have to go to the gen x kit? i only want to spray a 100 wet shot. thanks!
Old Jun 19, 2002 | 11:17 AM
hondakiller's Avatar
Default Re: how important are bottle heaters and purge sols?
bottle heater is a way to get the pressure up if there isnt enough and the purge is a way to relieve pressure and to get the air out of the lines. if the bottle is in the spare well you might not need a heater but itd be a good idea. purge hits the tires harder than no purge too plus it looks cool <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> also if you keep the bottle somewhere that the sun can get to it you might have lean problems with no purge to relieve the pressure.
Old Jun 20, 2002 | 11:39 AM
fastlif's Avatar
heater is good especially in winter, too low bottle pressure = less hp. purge is good but mainly for show. You can purge into motor if you have a button...not just WOT switch. without heater I used to run hot water over bottle untill pressure gets up.
Old Jun 20, 2002 | 11:43 AM
Chris Spiess's Avatar
both are more important with a wet system, particularly the heater so that you can maintain a consistant bottle pressure.
