NX MAF system
Old Jun 30, 2002 | 10:19 PM
Nitro Dave's Nitrous Outlet's Avatar
Default Re: NX MAF system
The NX maff kit is a great kit.It can easily be converted to a dual stage when ready.Just the replacement maff ends that come in the kit will give you 12hp over stock.We have a group purchase on them right now check it out.
Dave
Old Jul 1, 2002 | 12:36 AM
h53speed's Avatar
Default NX MAF system
I need nitrous... Had a older eclipse turbo with a 150 shot keep pace with me... Not good... I want to go with something that will be easily converted to dual stage and will have and easy installation... Would anyone reccomend this to someone with no nitrous experience... I know that I need to go with a colder plug and will probably need to get some with shorter ground straps to keep from getting the glow plug effect... Any info would be great...
Old Jul 1, 2002 | 08:36 AM
Bad Habit Bird's Avatar
We just put the kit on my car this past week and it is awesome. The build quality is top notch and the kit hits HARD <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> Here is a link to a few pics of when we were installing it. NX MAF
Give Nitro Dave's a call if you have any questions about nitrous or the kit.
<small>[ July 01, 2002, 08:37 AM: Message edited by: Bad Habit Bird ]</small>
Old Jul 3, 2002 | 09:39 PM
2K2T/A's Avatar
Can you give a little more info about the kit.How it work's???Thanks
Old Jul 3, 2002 | 11:26 PM
Basically the back section of the MAF is plumbed for nitrous. There are two holes in the rear bar of the MAF (one for each stage) The kit hooks up very similar to a regular nozzle kit but just to each side of the MAF instead of to a nozzle.
Once you hit the button the kit sprays from the back of the MAF into the motor and you get pinned to the seat! Its that simple <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jul 4, 2002 | 03:58 PM
The MAF kit is better than the "normal" kit because you dont have to worry about a nozzle going into the side of the bellow and it moving around. Also The kit comes with NX's new TPS switch instead of the regular micro switch that mounts to the TB.
The MAF setup does not make more power than the nozzle setup but it does clean up the install and it has two stage capabilities.
NX does sell a fuel pressure safety switch and other accessories. You should check into the GEN X1 and GEN X2 kits NX offers.
Sean
Old Jul 5, 2002 | 12:37 AM
2K2T/A's Avatar
Why is this kit better than the normal kit??? And does this kit have any safeguard's so my engine won't go boom??And does NX sell any extra safeguard's for it???All I want to spray is 100hp shot <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> To start with <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
