what should the plugs look like
Old Dec 1, 2012 | 05:19 PM
bBody22's Avatar
Default what should the plugs look like
as the title states what should the plugs look like on a good tune
Old Dec 2, 2012 | 05:23 PM
89L98T56's Avatar
I guess it all depends on your set-up.
Old Dec 2, 2012 | 05:27 PM
Carter01's Avatar
This is a pic from when I first started tuning. Looking back I was way rich rich but you get the idea with the fuel ring and timing mark on the strap.
Old Dec 3, 2012 | 12:44 PM
ATVracr's Avatar
Originally Posted by 89L98T56
That is not a good one.
Carter, that looks good.
Old Dec 3, 2012 | 11:08 PM
soundengineer's Avatar
yes... Rich in that one......LOL
but the timing mark on the strap is well defined...which is also a good indicator that you are in the right heat range...
if the timing mark isnt visible at all, you are too cold...if its visible, but looks blurry or smudged or smeared, then you are too hot
