New To Nitrous
You can run a nitrous kit by itself but I would suggest getting a tps if it doesnt come with one and a window switch. Also get a pressure gauge whether its on your bottle or in your car to keep an eye on things.
If you dont want to get a tune. Pull 4 degrees of timing and check you plugs and go from there.
The window switch would be great for activation.
here is what we offer.
http://nitrousoutlet.com/catalog/pro...2&product=4488
If the motor is sound, the LS1 will take it. The fuel pump is good to around 450 whp but with the mileage it could possibly be a little weak. I would keep an eye on the fuel pressure.
As far as timing goes, if it is bone stock you might be able to get away with on timing pulled but i would not chance it. I would pull the timing then work timing back checking new plugs every time you add some timing.
Window switch wise this is what we offer. Window switcher are great to have for a number of reasons. They can help you from spraying to low in the rpm and keep for from spraying on the fuel cut on the upper end of the RPM. If you were to do both of these it can cause a nitrous backfire.
