Which pill to use?
Old Jul 22, 2002 | 04:15 PM
BLUEBYU's Avatar
Default Which pill to use?
I have a 3000 and a 3800rpm turn on pill for my MSD window switch. Which would you recommend and why? I have the 5177 set-up with 100 shot nozzles. I run the TR224/114 cam.
TIA,
Randy
Old Jul 22, 2002 | 04:27 PM
2000 Camaro SS's Avatar
Default Re: Which pill to use?
How are your tires? Do you hook? If you do then try the 3000 I could not hook with 3000 and Nittos DR. So I used 3300 it helped a little. If your on street tires you might want to start at 3800 so you have time to get going and a better chance to hook.
