nitrous plate
But I would rather see how you blow something up by building a Nitrous plate when you appear to have no clue about how it works, have never bought one to cut apart and dissect, and have never tried to reverse engineer it to be able to design your own version.
the fact that you use "Cuz" (instead of the word Because) and you use "?" (instead of the word Question) shows a lack of respect for the English language, or a lack of education, or both....
and Things like that, are some of the reasons why you will get 100 views and Zero replies
I'm ready to see you turn some pistons into ashtrays.
I know you want to save some Money... But please... leave this kind of thing up to the Pros who do this for a living.
Buying somebody's pre-made ready to bolt on Product will save you a lot more money in the long run, and will yield a lot more consistent and reliable results than what you are doing right now.(not to mention, probably also safer results)
On a nitrous nozzle, the nitrous sprays behind the fuel. On the nozzle if you notice, there is what is called a bath tub. (the divet in the nozzle) It is used to 90 the high pressure nitrous into the fuel. It breaks up the fuel and atomizes into the airstream.
See the round hole where the nitrous comes out of the nozzle. It is set deep down in the hole. This is where the nitrous come out of the nozzle. This makes it do a 90 turn into the fuel. At the top of the tub you will see the fuel hole. This is where the fuel discharges straight down. The nitrous making the 90 degree blast threw the fuel atomizing both together. (excuse my key as a prop) LOL And no i do not drive a honda or acura. haha
They way that you are making your plate, you would be better off putting 2 wet nozzles in the plate with a 100 shot in each. This would net you the 200 hp shot that you want.
From what i was gathering you were going to use 2 dry nozzles, one with fuel in it and 1 with nitrous. Like stated above, most likely you are going to lean one side of the motor out with nitrous and float the rings on the other side.
I hope this helps. You have the tools to do what you want! Just feel free to ask questions! I will help out as much as possible.
OP is recommending a br6ef plug for a guy spraying a 175-200 shot in another thread. He is posting like is he knows what he is talking about but doesn't. That is the wrong info no matter how you look at it.
Yeah on the plate the nitrous hits on the fuel at an angle so that it breaks up the fuel.
