Nitrous controllers
...however, most would dismiss their products as overpriced...
I disagree and run a custom direct port set-up..along with 4 of their incredibly engineered to be progressive state of the art solenoids, as well as their hi-flow proprietary bottle valves...very well engineered pieces and very easy to use software in the controller...
The controller is well thought out and has many functions that allow you to control everything in your system including:
• bottle heat control and bottle pressure
• solenoid pulse frequency
• duration
• onset delay for nitrous
• onset and termination by individual gears or by time
• by rpm window per gear with variable reset options
• fuel pressure safety switch
• with a wideband tied in, safety control by real time AFR range
Check there stuff out if you have the budget...serious hardware with driveline and engine saving progressive onset...
Trev
Just to clarify one thing, the LNC letter designations refer to our line of launch controllers for the GM LSx equipped engines and currently includes the LNC-003 (two individual 2-step settings), LNC-2000 (one 2-step setting and a timing retard function) and the LNC-TC1 (one 2-step and an adjustable torque cut mode for no lift shifting on racing transmissions). The LNC-2001 will soon be released that is basically the same as the LNC-2000 but is designed to plug into the wiring harness found on the LSA engine (CTSV and ZL1) since they use a unique coil pack/injector harness configuration compared to other GM LSx powered vehicles. Previous products in the LNC product line include the LNC-001 and the LNC-002.
The current Lingenfelter nitrous controller is the NCC-001.
I didn't want someone ordering an LNC and wondering why it didn't look anything like a nitrous controller when they opened the box.
Our three letter prefix system for our electronic products can sometimes cause some confusion.
