HELP HAVING PROBLEMS WITH TNT
<strong>You say that it doesn't surge all of the time? If it surges's only after you have made several passes on your bottle, some times the TNT kits seam to do that a little when the bottles are half full or less. Also; I found a problem with my fuel noid. When you pull it apart, there is a small orange rubber piece that is supposed to seal it back up to stop the flow of the fuel; well, mine and others I've come to find out, that the orange rubber piece gets " Swelled Up " from gasoline and ends up partly or eventually fully clogging up the fuel noid and not letting any gas pass through. I replaced mine and gained 56 rwhp and 75 rwtq. And no more surgeing either!!!!!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That is from running CHEAP gas like CITGO I had my fuel noid quit working and I was spraying a 200 shot <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> Talked to James at TNT and he told me that cheap gas has Ethenol in it and the Ethenol swells the seals <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
I HEARD THE SAME THING ABOUT THE CHEAP GAS, AND THAT IS TRUE; BUT; i HAVE ALLWAYS; " ONLY " PUT EITHER EXXON OR MOBIL SUPER UNLEADED GAS IN MY Z06 AND I DID HAVE THE FUEL NOID SEAL SWELL UP ON MY CAR; SO I DON'T THINK IT'S JUST A BAD GAS PROBLEM; ITS GOTTA HAVE SOMETHING TO DO WITH THE RUBBER THEY USE ALSO; BUT YOU KNOW THAT THEY ARE NOT GONNA ADMIT THAT ONE!!!! " RECALL " !!!!!
