Wet kit question
Old Aug 12, 2002 | 11:00 PM
purevilss's Avatar
Default Wet kit question
With a wet kit, can you split the hose from the schrader valve for a electric fuel pressure gauge and the fuel jets for the system?
Thanks,
Old Aug 12, 2002 | 11:47 PM
SleepinZ's Avatar
Default Re: Wet kit question
Yes you can, just run a T fitting off the schrader valve, adapt the sending unit off the side of the T and then off the front run it to the fuel selenoid. hope this helps.
Old Aug 13, 2002 | 07:27 PM
purevilss's Avatar
Thanks!!!
