NOS Progressive Controller/ LNC 2000 Wiring
Old Feb 6, 2013 | 05:01 PM
EDS01SS's Avatar
Default NOS Progressive Controller/ LNC 2000 Wiring
Hey nitrous wiring gurus I need some input here. I have drawn up a wiring schematic using the NOS Progressive Mini Controller, the LNC 2000, FPSS and a linelock. I think I have everything drawn up correctly but before I go wiring this system into my car I would like to know everything is correct. Any help would be appreciated. Im trying to wire this up this weekend.NOS Progressive Controller/ LNC 2000 Wiring-nitrous-schematic.jpg
Old Feb 6, 2013 | 05:17 PM
EDS01SS's Avatar
The last picture sucked so here is a better picture of the schematic
NITROUS SCHEMATIC2.pdf
Old Feb 6, 2013 | 09:01 PM
Chopstix's Avatar
please let me take some time to really look this over....I did see a couple issues with the wiring to the solenoids...mainly pulling 40amps through a 1amp rated circuit. please look through my fquick link...I think I have one in there with a LNC and a progressive...also loook over the wiring sticky up top...there is a discussion about the progressive there at the end
Old Feb 6, 2013 | 11:20 PM
Somebody09's Avatar
my first question... +12V goes to 20A fuse, then into a NOS arming switch, through a light, and powers:
A) your NOS controller (until there's adequate fuel pressure, at which point the FPSS turns OFF the power via "Nitrous Relay". i think this should be changed to terminal #87);
B) "Nitrous Disable", which looks to have two solenoids;
C) "12V Retard Act." from LNC?;
D)the nitrous heater, and
E) the nitrous purge?
how many amps does the heater pull, and if you happen to purge while using the heater, will that 20 amp fuse blow?
what are each of your "spraying" solenoids rated at? enough to blow the fuse?
this seems wired so your heater can still be used while you're spraying. that might be a lot of amp draw...
Old Feb 7, 2013 | 03:57 PM
Chopstix's Avatar
Here is what I came up with...
Fuses
Yellow 20A
Green 30A
Red 40A
arrgghh...watermark
only wires to worry about on the LNC:
orange...connect to channel one output on 15974 (yellow wire)
Yellow...connect to output of line lock momentary
Old Feb 7, 2013 | 07:28 PM
EDS01SS's Avatar
Thank you chopstix, that looks great. seems much simpler then what I was trying to do. I will also go back into the sticky and check out some more of your schematics. I was in that sticky but i dont think i made it to the end.
