Mini + Twister question....
Old Feb 6, 2013 | 08:03 PM
LSOHOLIC's Avatar
Default Mini + Twister question....
Looking for feedback on NOS mini with the msd timing twister.....
Success ??
Any issues ??
Or any constructive input would be appreciated....
Thanks............
Old Feb 7, 2013 | 12:55 PM
LSOHOLIC's Avatar
Has anyone tried them together ??
Does anyone have suggestions or concerns when these two are ran together ??
Thanks.....
Old Feb 7, 2013 | 06:29 PM
krissoto's Avatar
One is a progressive, and the other is a 2 step and pulls timing correct? Just asking bc don't know about the timing twister, but one should not effect the other. Jmo.
Old Apr 28, 2013 | 10:15 PM
Jeremiahsc5's Avatar
I am in the process of wiring my set up now. Using the NOS Mini controller for the nitrous system and a MSD Timing Twister. I will let you know when I get it on the dyno. So far the diagram that comes with the NOS is pretty simple. I had to do some searching to find out how to wire the system with relays. The instructions from NOS have you not running relays. Also had to find out how to get the NOS trigger output to convert through a relay to fire off the positive retard output on the timing twister. I will keep you posted.
Old Apr 29, 2013 | 11:20 AM
brandon@nitrousoutlet's Avatar
The MSD Timing Twister just pulls timing I believe. OP In conjunction, I'm pretty sure they will do what you want them to.
