Nitrous Experts Inside Please!
Old Aug 18, 2002 | 06:37 PM
poolfanatic's Avatar
Badass pool player
Default Nitrous Experts Inside Please!
Thinking about going on the bottle again, but had some questions.
The car is an 01 SS with H/C and all the bolt ons. Dynoed at 446RWHP and 415 RWHP.
I'm only going to spray a 75 or 100 wet shot on top of the motor and then only infrequently.
This should be good for 520/530 RWHP and some serious torgue, but I'm wondering if my stock fuel pump and injectors are up to the task or if I should upgrade?
If I need to upgrade, what should I go with? Anyone else running a similiar setup?
Thanks!
Old Aug 18, 2002 | 07:04 PM
slow's Avatar
Default Re: Nitrous Experts Inside Please!
upgrade at least pump, and if the injectors stock can handle the motor, put a wet kit on.
if not, then upgrade, and run your choice of kits.
Ryan. <-- fan of wet
Old Aug 18, 2002 | 11:45 PM
Nitro Dave's Nitrous Outlet's Avatar
Yes,I would upgrade to a better fuel pump.Alot of the guys are going with the Walboro intank pump.
Dave
Old Aug 19, 2002 | 07:37 PM
Badass pool player
Thanks for the input! Anyone else?
Thanks!
Old Aug 19, 2002 | 09:02 PM
Country Boy's Avatar
Senior Member
If youre doing a wet kit, then you dont need different injectors because the kit supplies its own fuel. You will need to upgrade the stock fuel pump though. Anything over a 100 wet shot and the pump has to be upgraded. As you already have a H/C setup, your already stressin your fuel pump.
<small>[ August 19, 2002, 09:04 PM: Message edited by: Country Boy ]</small>
Old Aug 20, 2002 | 04:33 AM
EVIL's Avatar
get a walbro 340 intank and a good fuel pressure gauge so you can watch it from inside the car. you wont be sorry!
