why tq its so low (graph)
Old Feb 15, 2013 | 11:30 AM
PaSteLaSo4U's Avatar
Default why tq its so low (graph)
car made 400/360tq n/a. added a wet shot around the lines of a 125 shot and was a little dissapointed at the readigs was hoping for some real tq gains. n/a timing was 25deg and nitrous 18. tried more timing but didn't make a diff so left it low with 12.6afr. richer afr made no diff either
[/QUOTE]
rm
Old Feb 15, 2013 | 12:46 PM
zacht's Avatar
what rpm did you begin to spray at?
Old Feb 15, 2013 | 01:57 PM
the window switch is set from 3k to 6.4k rpms but theres also the microswitch on the t/b that activates at wot. I think it started at 4k ish on that test
Old Feb 15, 2013 | 02:24 PM
zacht's Avatar
you got a picture of the whole graph? with afr readings?
Old Feb 15, 2013 | 02:34 PM
Chopstix's Avatar
it looks like you picked up 125hp on your 125hp jetting...tq will be dependant on the rpm you are spraying it
Old Feb 15, 2013 | 02:43 PM
zacht's Avatar
yeah i'd like to see the whole graph...im thinking it just sprayed later than 3-3500...i would be happy with it like that...and it will last a lot longer than someone hitting 650tq....thats some crazy pressure on the rods...stock bottom that is...
