Long lines from solenoid to nozzle?
Old Apr 19, 2004 | 09:44 AM
SMOKINV8's Avatar
Default Long lines from solenoid to nozzle?
**I'm asking this specifically in regards to a wet kit**
In an effort to make my install a little cleaner for my wet kit, I'm wanting to move the solenoids to a little more discreet location than on/around the ABS module. Would there be any problem with having a (approximately) 2' length of line, instead of a 1' line, between the solenoids and the nozzle? I can't imagine there would be, but I could see it delaying the hit a little bit. And assuming it will delay the hit, would it be noticable on the launch?
Thanks
Old Apr 19, 2004 | 07:09 PM
Ben R's Avatar
There would be an ever so slight delay with a longer line, but nothing to worry about.
Old Apr 19, 2004 | 09:51 PM
SMOKINV8's Avatar
Thanks man.
Old Apr 21, 2004 | 08:30 PM
Z06PSI's Avatar
I have mine in the bottom driver's side wheel well (where the AIR system pump was). Got an all weather box from LOWES and stuffed everything down there and cleaned it up..... look at my pics....
