Spraying?
Old Aug 29, 2002 | 10:51 PM
Gun's Avatar
Gun
Default Spraying?
Could you have a system set up only to spray when you hit the button? Lets says I get a WOT switch but I'm street driving and some ricer wants to race so off we go and I'm already whupping him then at WOT/rpm range my n20 comes on and I totally destroy him. I don't want to spray unless I want/need to. Try and keep it a secret, hehehe. So could I incorparate a button I can push to activate the n20 only when I want to along with a WOT swicth so I don't accidential hit the button and blow my motor?
later Gun
Old Aug 30, 2002 | 02:55 PM
slow's Avatar
Default Re: Spraying?
yes, just install all the switches in series, so they all need to be on for the system to spray.
I did an install like this.
ARM---WOT---selector (a)---relay ---- MSD window-- ground
On the other selector switch side (b) it was like this
ARM --- WOT--- Selector --- Button--- Relay --- MSD window --ground.
So you had a choice, either just WOT, ARM, and Window range and you were spraying.
Or you could do WOT, Window, ARm, and Button on to spray.
But also remember, you will have a master arm switch, so you dont need to turn the system on if all your looking to do is be able to race ricers off the bottle.
Ryan.
