new to nitrous
Looking at your mod list you will need to upgrade your fuel system to a racetronix kit. The racetronix system will support about 650 rear wheel hp.
The fuel system upgrade will set you back about 200.00
The most budget oriented set up with out sacrificing quality would be our Brand X system. It retails for 499.99
The brand X single nozzle system place a nozzle in the air bellow before the throttle body. It will come with jetting from 50-150 hp. By simply upgrading the hose from the nitrous solenoid to the nozzle the system can support 200 hp. This is a great system and it is easily up gradable if you need higher hp levels latter on.
http://nitrousoutlet.com/index.php/e...00-150-hp.html
You will also need some accessories for the system to function safely and properly.
I would suggest a window-switch with TPS activation.
This is a great unit.
http://nitrousoutlet.com/index.php/e...ow-switch.html
We offer a Brand X accessory package that has all the main accessories grouped into one package or you can purchase only the accessories you want individually.
Here is a link to the accessory package.
http://nitrousoutlet.com/index.php/b...systems-1.html
I always suggest adding a nitrous filter so that trash from the mother bottle does not make it into your system.
http://nitrousoutlet.com/index.php/n...us-filter.html
You will also need to change your spark plugs to the NGK BR7EF Spark plug.
They are 2.25 each
Here is a great link to read up on what all the different system components do.
http://www.nitroustech.com/forums/showthread.php?t=2
We offer so many more options for your platform so if this is not what you are looking for let me know and I will help you figure out what fits your needs.
Dave
