e85 fuel pump for nitrous
Also they do not recommend running that pump on a return-less style fuel system without modification to the fuel system.
Here is a link to there FAQ on that pump.
http://aeromotiveinc.com/tech-help/f...th-fuel-pumps/
Personally I do not know of a fuel pump that I would recommend you run trying to pull that much off the rail being that it is a return-less style setup with E-85 . I would have to say with that much power either use a stand alone tank or possibly switching to a return stye fuel system. If I were you I would call Racetronix and see what they recommend.
Trey
