Can an hsw interface and timing tuner be installed at the same time?
Old Mar 19, 2013 | 09:43 PM
its turbo time's Avatar
Default Can an hsw interface and timing tuner be installed at the same time?
I have the timing tuner w/n20 controls and an hsw interface and just realized they both install almost the same. They both use the ground circuit through the nitrous solenoid and both use the wot switch wire.
Can they both be used at the same time?
Old Mar 19, 2013 | 10:47 PM
Think I figured it out, I just need to attach the blue wire of the interface to the output side of the timing tuner and then attach the brown wire where the out put side of the timing tuner previously was (the 85 ground of the solenoid relay)
Basically it's going to activate the interface whenever my timing tuner is activating
