Nitrous on my 98 Trans am
Old Mar 23, 2013 | 03:47 PM
Joes98Blackbird's Avatar
Default Nitrous on my 98 Trans am
I have a question? I have a cam, stall, full exhaust and a 85mmTB/LS6 intake on a 1998 Trans am and I was wondering about trying nitrous. I am going to have the computer swap to a 2001 and tune at EFI in Jacksonville FL. this coming spring, but I've heard that you will have to run bigger injectors for just a 100 shot. Is this really true for just the juice that I want. I have a Walbro Pump and i'm Installing fuel rails on the car next week before I take it up there for the tune. I wanna hear what yall guys have to say on this..... Stock injectors or 03/04 cobra injectors as an upgrade to handle the nitrous...? Thank you very much?
Old Mar 23, 2013 | 05:04 PM
HCI2000SS's Avatar
I would definitely do it! Personally i'd go with some 42's, so it will give you a little room to grow as well
Old Mar 23, 2013 | 09:21 PM
krissoto's Avatar
Only reason you would need a larger injector is if you go dry.
Old Mar 23, 2013 | 09:55 PM
egod's Avatar
like Krissoto said the injectors aren't maxed out. Usually its the full pump that needs the upgrade first and it sounds like you have that covered. Best of luck.
