nitrous tune, Need Help!!
Old Apr 4, 2013 | 12:54 AM
busha61067's Avatar
Default nitrous tune, Need Help!!
Im planning on running a 175 shot, i have #7 plugs, will be using higher octane gas prob 110, does anyone have a hp tuners spark table i could look at for reference to make sure my timing is ok il probably take out 7-8* of timing
Old Apr 4, 2013 | 07:49 AM
dnkynrbk's Avatar
Take out 8 degrees id run #8plugs. But u need to ger a good NA tune at the track with the 110 before. Just to get it all lined out.
Start smallon shot check ur plugs.
Old Apr 4, 2013 | 11:45 AM
Neal@NitrousOutlet's Avatar
Depending on what your compression is will also depend on what plugs you will use. If you are still stock compression then you will be ok on BR7 plugs. If your compression is higher than you will want to get into some B8EFS plugs. 7's are good to around 200 hp on stock compression. After that i would change out to 8's.
