need some wiring help
Old Sep 21, 2002 | 07:41 PM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
Default need some wiring help
Ok a buddy of mine has a problem. As soon as he hits the nos( its a wet kit) It goes lean for like a split sec then goes fine. During this time he loses 40+hp. i was wonder if he could put something to delay the opening of the nos a split secound after the fuel opens up. Whats happening the pump cant keep up when he first hits it. So I would like to try this as a temp fix. What do I need to put inline to make this happen?
Thanks
Old Sep 23, 2002 | 05:53 PM
383LQ4SS's Avatar
Default Re: need some wiring help
Dont do that. You really have to fix the initial problem. Wet kits of all types are run everyday without the problem you describe. Your problen is a symptom of something bigger. Fix it.
Maybe location of the fuel noid (too far from the nozzle). Maybe a pump not up to par or going bad? A fuel noid sticking momentarily? Or some type of blockage in the fuel line. Whatever you do dont jury rig. Fix it right.
Old Sep 24, 2002 | 05:24 AM
Bode's Avatar
Your friend did remove the internals from the schrader valve at the end of the rail right?
I know it's kind of a dunb question but I had to ask anyway. <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
