timing twister users come in
Old Apr 9, 2013 | 11:28 AM
brandon6.0's Avatar
Default timing twister users come in
hey guys i have my timing twister nitrous activation retard wired up to pull timing with the arming switch. On the street i can notice the timing being pulled before i actually trigger noids. Would it possibly run faster with the retard wired to the wot switch instead of arming switch? Has anyone else ran theres like that. Thanks guys!
Old Apr 9, 2013 | 11:35 AM
HCI2000SS's Avatar
That's the way I am setting mine up , but i'm using the LNC-2000. That way it only pulls timing when the window switch kicks in and the nitrous is actually spraying
Old Apr 9, 2013 | 10:19 PM
brandon6.0's Avatar
Ok thanks anyone else?
Figured I can be making full potential off the box and run my normal timing and turn back only when spraying. Would it be safe like this tho?
Old Apr 10, 2013 | 10:12 AM
Rise of the Phoenix's Avatar
That's the purpose of the timing twister; to only pull timing when spraying so you can be at max power when running N/A.
Old Apr 10, 2013 | 02:17 PM
brandon6.0's Avatar
Ok we'll guess I'm about to give it a shot like that thin. Thanks guys.
