dry nitrous sucks
[QB]johnster,for what it's worth , you should keep the bottle pressure below 1100 psi or it will turn from nice liquid form into a gas and give you less of a gain. i was told that by a friend that sprays his GTO and runs (7's),so i trust him.
I do not believe that... the bottle pressure is changed by bottle and ambient temp. the warmer the bottle the higher the pressure. NOS changes from a liquid to a gas when released to the atmosphere due to ambient temp.. i can not remember the rules of latent heat and other stuff i learned years ago in refrigeration.. but same rules apply... thats the whole reason for purge valves.. to bring liquid NOS to the solenoid.. if the NOS is not used right away it will turn into a gas again..due to the ambient temp of the line, solenoids and such. the bottle pressure does not change its state... Not saying there may be other things at work but bottle pressure will not change NOS state...
However...if in fact nitrous does shift properties at approx 1150 psi..i still think its ok to spray a dry 5177 kit with bottle pressure 1150-1175 psi max with no ill effects on power. Heres why. If in fact the nitrous is more of a suspension with a bottle at 1175 psi..when the nitrous noid is opened and nitrous starts to flow toward an opening...the pressure will drop some due to Bornoullis Principle (as flow increases pressure decreases)...reconstituting the nitrous in a liquid form. So in order to have negative effects you would have to be even higher...say 1250-1300 psi before you may see a loss of flow.
I very well could be way off base here but thats my story and im sticking to it <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
I have dynoed on nitrous quite a bit. I have always seen increases with higher pressure on the dry kit. Very noticable gains in power between spraying at 950 and then 1050. Same gain seems to come from 1050 to 1150 , anything above that and it seems to level off or reduce performance.
But...running at such high pressure has other downsides....there will be more of a pressure drop when spraying from a higher starting point. It would be better to keep pressure down to say 950 and use a bigger jet to flow the same amount of nitrous.
Just a few ideas and thoughts to throw out there!
<strong> does this sound right or not.you guys are still raning faster.one guy on here said he went from a 8.30 to 7.40 same dry shot of n.o.s.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">that was me 8.3 to 7.4, what was your 60ft.?
on my 8.316 run i had a 1.825 60ft
on the very next run (spraying) i went
7.417 with a 1.582 60 ft.
i launched on the gas and pretty much dead hooked.
the front tires came up about 2 inches.
i think alot of it is my st3500 it loves nitrous!!
Pressure, temperature, and volume of the container all will affect the state of N2O. Since the volume of the bottle is not changed if you increase the temp you will increase the pressure. Nitrous changes state to a gas when released from the bottle because of the large pressure differential between the atmosphere and inside of the bottle. In its normal state at ambient pressure and temp N2O is in its gaseous state. It has a very low boiling point. So to change it to a liquid you must either lower the temp to below its boiling point or increase the pressure. The higher the pressure the more flow thus the more nitrous through the jets = more power. N2O changes state at the jets ideally. Too high a pressure and flow however, and N2O may change state across any other restriction like a bottle valve and I believe this is what causes the peak in power. I do not believe it could change states inside the bottle under even 1500 psi unless the bottle was REALLY hot.
