Mounting the Nitrous Bottle Side ways???
Old Apr 17, 2013 | 02:25 PM
ISprayOnU's Avatar
Default Mounting the Nitrous Bottle Side ways???
Can I mount The Nitrous bottle sideways with no Problems or is it better to mount them straight? Is there a rule on having the nitrous bottle sideways with NHRA rules?
Old Apr 17, 2013 | 03:38 PM
brandon@nitrousoutlet's Avatar
The bottle should be at least at a 15 degree angle or vertical. If you do it vertical then make sure the siphon tube inside is facing the rear.
Old Apr 17, 2013 | 04:00 PM
JoeyGC5's Avatar
I have my bottle mounted at a 45 degree angle from the front of the car with no issues. I also tilt the bottle so the siphon tube is at the lowest rear-most facing position.
